Can I caulk this?
BodeFamily
33
Pittsburgh, PA
CircuPool Core-55
I think my pool was built in about 1980, and it has some kind of metal coping. I noticed the other day that some of the seal between the flagstone and the coping is gone. I’m guessing I don’t want water getting down there and freezing/thawing all winter. Can I just re-caulk the parts that have come up? Or is there some other special something I should put there? In my search, most of the pictures and posts were for concrete or stone coping.
In 2018 I had my expansion joint redone. I found some old pictures of the product and them applying it.
Hope this helps
Reactions: BodeFamily
View attachment 533076View attachment 533077
Would need to put some poly-foam (pool noodle) type material in the gap to keep any sealant from just falling into the void.
Along with using some backer rod (foam) to help fill in the gap You also want to use the correct caulking which is usually a flexible polyurethane sealant - quickrete makes some. There’s several brands.
