Is Borax decahydrate (Na2B4O7·10H2O) correct to use ?
Hi all
Just wanting to make sure I have this right before I risk poisoning the pool water in the morning.
After the recent drain and refill, I have the readings ( from a liquid 4-in-1 test kit ) :
FC 3
TA 80
pH 7.3
In addition, the test strip gives the following :
FC 3
TC 3
Alk 100
pH 7.2
TH 100
CYA 35
To raise the TH from 100 to 200, I will add 4kg calcium chloride flakes ( already had these as we use them to de-humidify cupboards ).
Next, pH from 7.3 to 7.5 with 500g Borax.
My concern is the Borax.
I went to the local chemical company and got 'Borax' ( 25kg ~$25 ). The packaging says : Borax decahydrate (Na2B4O7·10H2O) min 99.9% Granular. Is this the correct stuff to use ?
I also want to use the Borax and hydrochloric acid to add borates ( to get to 40 ppm takes 13kg and 6,5 liters acid ), but am a bit stuck as I do not know the borates starting level. I am unable to source borates test strips in our country. Is there an alternate way to test ?
Hi all
FC 3
TA 80
pH 7.3
FC 3
TC 3
Alk 100
pH 7.2
TH 100
CYA 35
