Hi everyone. I've read most of the post regarding the subject pumps and called Pool Supply Unlimited and emailed Calimar. No answer yet. I have a shared body pool/spa. I am looking to buy the Calimar 3HP variable speed pump and the add-on automation controller. I want to set the pump schedule to run my pool using speeds 1 and 2, then use a relay (in my DIY pool automation system) to run speed 3 when I want my SPA active. If the schedule in the pump has the speed 3 duration set to 0 minutes, what happens when I engage a relay (close the relay) on the pump controller terminal 3 to the provided 5V terminal? I expect the pump will run speed 3 until the relay is opened. But that's not what's implied in the pump instructions nor the automation controller instructions. They imply the pump will run speed 3 for the duration set in the pump schedule (which will be 0 minutes for me). Can someone verify that engaging terminal 3 with a relay will in fact run speed 3 while the relay is closed, even if the pump has that speed schedule duration set to 0 minutes?
Thanks!
Thanks!
