When I was handed the keys to pool at end of February, my CH was 140. I strive to keep it at 260-270, and probably need to go higher. For awhile now I only test those numbers about once per month, and each time I see some CH loss from previous. So, my mind has been haunted with a pool leak, but with no water loss other than maybe 1/4" evaporation on average days. Autofill has been off and on to see, and I just can't pin down if there's a big maybe that a small leak could be hidden in that measure. Some days it's even only 1/8" evaporation as the days get shorter.
The CH loss appears to be around 20% over 1.5 months to 2 months, or so. In total, since starting at the 140ppm, in total I have added 24lbs of calcium chloride increaser - let's say 8 months. My fill water is 40ppm. We have had maybe 3 deluges of rain in that period that overflowed, but otherwise we have been completely dry. Pool math says that's a lot for my roughly 16K pool without considering any normal exchanges. I bought a speed-stir and started testing with that yesterday to make sure my testing method was more precise. Same measures. Also, my CYA level does not seem to drop accordingly and holds.
I guess I'm looking for advice as to whether some of the rain exchanges could contribute, other factors (though I know loss it probably only), or, I just need to go much higher and see what happens. Or, if I call the PB and ask for a leak detection when I can't describe losing water to them, just CH loss. Any suggestions?
