- May 24, 2023
- 3
- Fiberglass
- Hayward Aqua Rite (T-3)
Hello All, First time poster here at TFP. Also first year owning an inground pool approximately 18,000 gallons, it was just installed end of last year, fiberglass and will be SWG. I have had other smaller pools in the past off and on but never put in as much effort and research as I have this go around for chemistry and other pool items. So my question is mostly regarding Calcium levels and why such a dramatic difference from recommendations at TFP versus some other pool companys.
Recommendations from the TFP calculator for my pool with SWG
PH 7.6-7.8
TA 60 -80
Calcium 350-550
CYA 70-80
Chlorine based on the 5% relationship if CYA 80 then 4ppm chlorine
Two other pool companies online information
PH 7.4-7.6
TA 80-120
Calcium 200-400
CYA 30-50 (80 max)
Chlorine 3
So for ph and TA we have some minor variances but I would not consider them that huge of a difference, for chlorine and CYA their recommended would not be adequate for the 5% relationship but with their max CYA value there is room to make that work.
I am just curious why such a large difference in Calcium recommendation?
Anyone with a fiberglass pool and SWG what do you run your numbers at? I live in southwestern Ontario Canada if that plays into anything for weather wise.
Thanks for any input
PH 7.6-7.8
TA 60 -80
Calcium 350-550
CYA 70-80
PH 7.4-7.6
TA 80-120
Calcium 200-400
CYA 30-50 (80 max)
Chlorine 3
