We use trichlor on our commercial pool and we use an IPS ORP controller that opens the valve when the ORP goes below setpoint. It's a severely flawed system as ORP does not play well with CYA higher than 30.
The local pool supply is talking me into switching over to using cal hypo instead of trichlor. Is this a better system than using trichlor when it comes to having an ORP chemical feeder? I'm basically switching over from CYA to Calcium as a UV protectant.
As an added note, we replaster the pool and jacuzzi evert 5 years, the pumps run 24/7 and they are both heated. 38k gallon pool and 1.6k gallon spa.
The preferred disenfectant is liquid chlorine, but our pump room is too small to accomodate for it.
I'm also looking into salt water chlorine generators, but I hear that it's a slow feed and can't keep up with commercial pools with high bather loads.
