I appreciate this thread as I've been having the same questions on CH. I am struggling to know of what I have is good or if things need adjusted. To complicate matters even further I am uncertain how to read the CH test properly. Is it when it goes from red to purple or do I read it when it goes to a true blue color??
Today's readings (~25k gallon, hydrazzo plaster)
Ph = 7.8
TA = 160
CH = 250 (turns purple)
FC = 1.2
CYA = <30
These numbers have been very steady since we got it up and running late last fall. The PH tends to creep up to 8.0+ (highest reading) and I periodically add acid to drop it.
are these ok and if not what should I shoot for?
Ph = 7.8
TA = 160
FC = 1.2
CYA = <30
