Inground pool chlorine,
Most plumbing has been replaced. Pump seal kit is new. Filter is new. New skimmer installed last year also
No water loss, pressure is fine and rises as it should but still have tons of bubbles. Most seals and o rings have been replaced. I also have a lot of bubbles in the pump basket and I do hear some gurgling noise in the skimmer suction line when the pump is running but pressure seems fine and rises like I mentioned, but still bubbles in the return. Not sure what else I can do
I have not pressure tested the lines underground but I do fear that it could be a problem.
