I have a 360 gallon “My Life” hot tub, just installed new, last October. Chemical treatment system used is the Frog. Sadly, I keep getting a nasty, dark brown sludge in my tub; almost the consistency of chocolate pudding. pH and all other parameters are in spec. The local hot tub store had us change the Frog, didn't really help. The only other chemicals ever used are the Caribbean Spa line of products (pH decreaser or increaser, Foam Free, Enzyme Plus, and Clarifier). I’ve changed the filter twice in 9 months. I’ve gone through more Frogs than I can count. Yesterday, I opened the tub and it had what looked like some sort of jelly fish goo was in the water. The last chemistry checks were: pH 7.19 (by meter), total alkalinity ~120, total hardness ~250. No actual chlorine measurements – the color strip indicates that it is spot on. It seems that this nasty brown pudding appears about 12 hours after adding pH decreaser, but, this could just be my imagination trying to find a cause. The water supply is the same as my inground pool and I have no problems with the pool chemistry. Any thoughts or ideas?
