Your pool service may have been using copper to prevent algae. The tabs have probably increased your CYA way above recommended levels.
Normally I recommend that pool owners stay out of pool stores and test their water themselves. A properly maintained pool does not require phos-free. In your case you want to keep the copper in solution until you remove the copper by refilling or reverse osmosis.
As a preventive measure to prevent copper staining you could add the proper Jack's Magic solution. The pool store could tell you if you should use the “Pink Stuff†of “Blue Stuffâ€. Copper stains are very difficult to eliminate.
