We have a booster pump that runs our water feature and slide. It switches between the 2 (slide and water feature). When the booster pump turns off most of the water will drain from it so the next time I turn it on it will not fill and run. I can get it to work by turning it on then off quickly and watch water fill above the tube coming into it. It takes a few tries of turning it on then off before it will fill with water, prime and run correctly. Any thoughts on why this would be happening ?
