Is there a pool waterfall pump (low pressure high flow) that can deliver 210 GPM? I'm having a hard time finding one and 210 was the requested flow from the waterfall builder.
What is the plumbing size for the suction and returns?
Suction should not exceed 6 ft/sec and return should not exceed 8 ft/sec.
Size.......6 ft/sec......8 ft/sec.
1.5"...........38.............51 gpm
2"..............63.............84 gpm
2.5............90...........119 gpm
3.0"........138...........184 gpm
4"...........235............312 gpm.
Assuming a 4" suction and return, the head loss from the plumbing should be less than 7 feet and the flow should be 210 GPM at about 2,750 RPM with the commercial 5 HP Intelliflo XF (Assumes a total of about 20 feet of head loss).
You will also have some head loss from the height of the waterfall and the other fittings like the wall suction.
How high is the waterfall?
What suction grates are being used?
At 30 feet of head loss, the speed would need to be about 3,000 RPM.
