Perhaps, though that still seems a bit of a stretch. Sometimes we can't figure out what happened, unless it's something common across a bunch of pools so that we can isolate various factors more easily.brucek2 said:CH is up to 250 now, if I reach a point where there's no rising pH at all maybe that'll mean it wasn't the aeration and it was period with low CH?
So the water that spills over the infinity edge isn't recycled back into the pool? So I guess that's not a waterfall effect (so I was wrong about aeration in that case) and it's just treated as splash-out. You might not see dilution in TA or CH depending on the pool levels relative to the levels in the fill water, but there shouldn't be any CYA in fill water so if you don't see that dropping and you aren't adding CYA (say, via stabilized chlorine), then yes your loss from the infinity edge must be small.brucek2 said:I have not added water myself since the refill, although there's been some rain. There's also an auto-fill valve on the trough outside the infinity edge. The water level in the main pool is always right up to that edge so I don't see many clues either way as to how much water is lost or added. I haven't seen dilution in TA, CH, CYA though so I'm guessing that fill water influence so far has been small?
