Update for today, which is not a perfectly good update. Here's a new picture of my setup:
I've been running the pump all night, and this morning I'm detecting 4 small leaks, 3 of them are where the SWG is hooked up. Here's a closeup of the SWG:
Both threaded adapters are leaking, maybe a couple drips per second, and there's a very slow leak in the cap over the copper bars of the SWG. Their wierd thing is I haven't modified that copper bar cap. The fact that it leaks suggests either a manufacturer defect, or maybe I didn't screw it on tightly enough. Maybe I should put some sealent in the threads under that cap. I don't foresee ever needing to open it..
As for the other threaded adapters that I did install, maybe I should following this advice:
Ditch the Teflon tape for a bottle of TFE Thread Sealant Paste.
(To be fair I did put silicon in there when the teflon didn't work well.)
Looking at home depot's website, I don't see this particular brand, but they do sell lots of thread sealents. Examples:
The good thing about all these leaks is that due to locations of my unions, I can easily disconnect and reconnect these adapters, and when reconnecting, the exact angle of how tightly they screw on doesn't affect their ability to be positioned correctly for reattachment to my piping system.
The 4th leak is potentially more worrisome, which is the threaded adapter next to the return jet:
I can easily disconnect it because of the union you see there, but if it doesn't screw back in the exact same number of degrees +/- a multiple of 360 degrees, it won't line up with the union. Well I think I might have it screwed in as far as it will go, because of the silicon I put in there - I think allowed me to screw it in all the way. (Note: there are two threaded adapters there - one was included by the pool installer, which converts the 2" opening to a 1.5" threaded opening. The one I installed is the one where you don't see exposed threads.) Hopefully this means it screws in to the exact same position if I redo this. I should mention I'm detecting 3-4 drops per second from that adapter when the pump is on.
I guess I'm not in a rush to make these repairs, because the pump is working and circulating my water, but I feel like I should still address this.
Funny that my silicon says that besides lubricating, it may be used on threaded parts, but it's apparently not doing a good job of sealing.
