tcat
- May 30, 2012
- 1,611
- Plaster
- CircuPool Edge-40
Oh - I have been reading it a lot. I think I give another couple of months but keep updating the thread with any data.Check out my thread on the Aiper Scuba S1. Really starting to enjoy it.
I just took a piece of 1" foam I had laying around, cut it to make a divider that sticks out a little. It seems to steer away from it. Or you can turn skimmer flow down a little if your skimmers have a separate valve. You barely need them if you run Betta 24/7.Got the SE Plus and it was hung up in skimmer current within 5 minutes. Not enough power to pull away from it and I’m only running the pump on a medium speed. Don’t want to turn down the pump or put barriers around the skimmers because they do a fantastic job. Was hoping to just help them out with the Betta. Bye bye Betta.
I’m very happy with ours.The SE Plus is now on sale on Amazon for $359. I'm thinking of pulling the trigger. Worth it?
It's worth $500, so yes.Yes, and go back and buy the 3 year extended warranty.
Tell us if you purchased it. Did you purchase the warranty separately from Betta directly?The SE Plus is now on sale on Amazon for $359. I'm thinking of pulling the trigger. Worth it?
