"best?" way to add DE after a full filter clean with a variable speed filter
Pentair FNS 60 with the curved vertical grids. Sta-Rite VS 3050 pump.
I always clean with a full disassembly and cleaning. 4 way backwash valve was removed years ago.
My question is what's the "best" way to recharge the DE with a variable speed pump?
I make a slurry in a 5 Gal bucket. Add a coffee can of DE to about 4 gals of water. stir it up and slowly pour this into the skimmer.
The coffee can I have is slightly smaller than a 2 lb coffee can, so just under a pound of DE per bucket-load of water/DE mix.
But by the next cleaning, I almost always have a pile of DE at the base where the grids align and don't get the DE coating I would expect.
I've tried high-speed ( about 3200 RPM ) and mid range, but I haven't found a consistent way to evenly coat the grids.
Is there a tip for doing this I haven't seen?
Should I add less DE to the water bucket and spread this out over time?
Do I need to keep the pump running at a high speed for a long time to get the DE to cake up properly?
I wish I could see inside the filter to know what is going on...
Tnx in advance for tips or suggestions.
