New house with a unique pool design that makes maintenance a nightmare.
1. The middle of the pool has some sort of trench running through the bottom about 1-2 feet deep and 2-3 feet wide at the largest point. It starts near the middle of the pool behind the island and runs to the deep end on the right side. I need a robot that will be good at climbing in and out of this. I have heard that the older dolphins with an "arm" on top climb well so I was considering the z5i since it can be had for under $1000 and seems to have beefy specs for that price including dual drives and wifi control.
2. Another consideration is that the pool has an "island" in the middle, so I need direct wifi control in case the cord gets wrapped around it. I know wifi control is bad on these but I think even bad control would suffice just to reverse it back around the island.
3. The pool is also swarming with oak trees so large filter capacity is helpful.
4. Lastly, you might say that a pool like this isn't the best for a robot, but unfortunately it's at least 8 feet deep (not counting the trench) so brushing the bottom is extremely difficult, and one side is inaccessible because of a rock waterfall. Even if the pool doesn't get spotless, a robot can still help a lot by stirring stuff up in the trench and deep end.
I was thinking of grabbing the z5i since it seems like a good deal for the specs, but I don't know how it compares climbingwise to the s2000 type bots or if there is something else i should look at.
