We recently bought a used 2015 Beachcomber Leap 540. All was going well except that on rare occasions while the jets were on max, they would slow down briefly (1-2 seconds max).
Last night we went out and the hot tub was lower in temperature. Jets worked, but on high were not quite as powerful. I turned them off and noticed a humming coming from the hush pump (located behind the main pump). Here is a video of the location and noise coming from that pump: New video by Andrew Mueller. I did shut power off to the hot tub so I wouldn't fry the motor.
What is the likely issue here? The hot tub was running fine for about a month (except for the low flow through the jets that happened infrequently).
Thanks in advance!
Thanks in advance!
