Had my pool built last year and had a basket ball hoop sleeve installed. I'm just a little clueless on what needs to be done from here. Is there a certain type of hoop I install or what? The PB just said to buy a basketball hoop and it will slide in. If I look down into the sleeve there's a bolt I'm guessing the basketball hoop tube needs to be notched? I'm guessing that bolt keeps the hoop from spinning. So I guess my question is do I just buy a basketball hoop that has the pole dimensions to fit inside my sleeve and I cut it myself for the height and put a notch in it? Does anyone have any other ideas?
I believe this is the sleeve used.
Sleeve link
Sleeve link
