Hello,
I have a very basic pool set-up. My pump has it's own inbuilt timer and my UV system and lights are controlled by a flow switch and manual switch respectively. I have a cartridge filter, so do not need to backwash, and no heater or spa.
I would like to add a Jandy valve and actuator to my suction line, so my suction cleaner can come on for an hour or so every day without having to turn the valve manually. What is the most simple way to do this? All the controllers I can find control pumps, spas, lights, heaters, etc... Which is not necessary for my pool. I only want to control one valve On or Off.
Than you very much.
Than you very much.
