It sure does look like it's leaning though! But it must be the angle I took pic. Btw, I'd glad we're draining it. Hubby swore to me that he would be able to put the 15" x 15" blocks under the supports while it was filling. In my mechanical mind, I didn't see how that was possible! Umm let's see, the supports are called supports because they support the wall of the pool that is filled with water and keep it up right. So he went out this morning (didn't believe me when I told him it was leaking) and attempted to dig out under the support to put the blocks in. Well, that is almost impossible, there is no way to tell if the block is level with the foam under the pool! So now he will be able to do what I suggested as usual!
The problem was, there are no measurements any where in the instructions other than the size of the pool and the size of support pads required. So he didn't know where to put them until the pool was up. He said he didn't know if once the pool started to fill if it would extend out more. But imo that's why they stated 15 x 15" pads.
Back to square 1.
Back to square 1.
