If water or anything else is returning to your pool when you are on the "waste" setting, there is something wrong with your multi-port and you need to get that fixed or your pool will never clear.
chisch said:I just did a successful Baqua conversion this year on a 14K gal pool and it only took a week.
First I added about 10lb of calcium hypochloride (Ultima TKO brand) and watched some pretty colors and milky-ness for about 3 days before I vaccumed the pool to waste, retested, and added about 10 more lb of the cal. hypo. After 4 more days I was holding chlorine decently and decided to plumb in the Hayward chlorinator I had purchased for my conversion, as well as change the sand. I loaded the chlorinator up on tablets and turned the knob full blast. Less than a week later I had almost sparkly clear water, and now 2 months later everything is still great.
I think the key points are oxidization of the baqua-Crud out, good filtration(aka change the sand after the conversion), and a constant chlorine source.
jblizzle said:I hope you realize though that relying solely on trichlor pucks as you source of chlorine is doomed to failure unless you have a very short season and drain off a lot of water when you winterize: pool-school/types_chlorine_pool
