I installed the Balboa VS500Z pack from Spaguts.com in April 2017. This weekend the control panel started registering code HL (Difference between temperature sensors and a possible flow problem) and eventually LF (persistent Low flow problems) The heater shuts off and the temperature drops significantly.
None of the issues Balboa suggest seem to be present. Water level is normal, pump seems primed, changed filter.
I can keep resetting the pump and it will eventually heat back up, but I have to be in the tub hitting the pump button every 5 minutes or so to make that happen.
Any other options, recommendations to get this cleared?
