My new 2023 A6L Select's Neck'PLUS' JetPak, which is new for 2023, seems to be a problem (for ref.:2013-2022 had NeckBlaster & NeckMasseuse). NeckEASE is the other Neck JetPak for 2023 model year. Pictures attached.- When I removed the headrest covers to purge the hot tub, I noticed that the fronts of the protrusions over the shoulders were very roughly cut with slots, like with a grinder wheel. The cuts did not match side to side, looked rough, like the assembly line tech was NOT paying attention (built on a Friday/HIGH day ?), and the headrest covers do not snap over on these front extensions. What are these "manual cutouts" supposed to do??? With the pump on low, the one over the right shoulder sprays a disfigured stream, on high the stream is disfigured and very forceful. The one over the left shoulder on low squirts up and in all directions, on high it sprays in your face and all over. Does your 2023 Bullfrog have this specific NeckPLUS JetPak? If so, does it have holes or manually cut out 'slots' in the front of the extensions over the shoulders that spray horizontally? From the web pictures of the two 2023 Neck JetPaks, the top (2) neck and (2) shoulder jets seem to be identical between the two. It looks like the only difference is in the choice of the (2) lower back and (2) upper back jets on the lower part of the JetPak.
Before I go talk to my dealer, I want to be educated as to what the 2023 NeckPlus JetPak is SUPPOSED to look like and how it is designed to function. Meaning, is water supposed to come out of the two extensions horizontally, in addition to the four neck/shoulder jets. I hope a 2023 Bullfrog owner can help me out here. I could not find any pictures or videos showing a NeckPlus JetPak in operation.
Thank You,
Dave
Thank You,
Dave
