- Aug 1, 2022
- 9
- Fiberglass
- CircuPool Core-55
I recently opened the pool with the help of a local pool company. Since opening, I have this issue where the pressure kept rising (25%+) over a 3-4 hr period and so I have been backwashing to get it back to a normal psi (generally around 14 psi at 3000 rpm). However, I have noticed since I opened that the water is not exiting to the street when I backwash; however it will start exiting to the street when I rinse (I have a 300 lb sand filter). I found out after the fact that the pool company put in some phosphorous remover and then read that those can have clarifiers which can cause clumping in the filter. After 5-6 backwashes, the pressure doesn't seem to be rising as fast so I am hoping that it has worked through the system, but I am concerned about the backwash not seeming to go to the street like it used to. Is it possible that the chemicals they put in are causing the filter to get clogged when it backwashes? Any recommendations?
