I have a AutoPilot Pool Pilot Digital Nano and want to make sure it's working as it should. I've read the manual and the cell details for volts and amps - and understand the basics. The Nano was installed about 7 years ago, and I had the main unit replaced 2 years ago due to a faulty display. I have just replaced the cell with an "AutoPilot Pool Pilot PPC1/RC35/22/Super Cell SC-36", primarily because the old one was 7 years old, and though I clean the cell regularly I have not been getting the chlorine output I once had. The system check light is off (no faults). I also reset the Cell via the installer menu. Pool is 12,500 gallon, salt is at 3500ppm and other chemistry is good.
With the water at 82 degrees (f) the old cell was at 14v and 3.0 amps on normal Nano settings. The new cell is now also at 14v and 3.1 amps. Setting to boost, it still reads 14v and 3.1 amps. Aside from the basic settings set via the installer menu, there have been no changes to 'programming' since new. The cable appears good - no burn spots or contact corrosion. I did give the contacts on the connector at the cell end a shot of De-Oxit just to be sure. I also double checked that the Nano was wired for 120vac.
From the charts below, it looks like I should be at anywhere from 16 to 21 volts? Any thoughts?
