I've been searching and can't find an answer that seems to work for what I'm thinking. I know this is "simple", but I haven't seen a post (or not searching correctly) for what I'm looking for.
I have Raypack Heat Pump and currently 2 speed 1.5hp pump. I will be changing over to a IntelliFlo VS pump, because I like the cost savings on energy use and the programing functions of the speeds. My flow meter reads about 40gpm on hihgh and I use .8kwh pulling around 9amps. I am trying to go more energy efficient where I can. I run it 24/7 on high speed. My heater will run on low speed, but I don't know that speed because my meter doesn't go that low.
How do I control the heater with the VS pump? I only want the heater running on "high" speed. I've seen about controlling it with some wiring from heater to VS pump, but I can't seem straight info that I need. I also, don't want the heater running from the hours of 9pm-8am. How do I control both? I have looked into automation, and yes it's very expensive, but I do like the features (Waterway Oasis). I won't be changing over to the new pump until next spring, but If I could control when the heater runs now, that would be cool.
Thanks for the help everyone.
