tloomos
- Nov 15, 2022
- 54
- Plaster
- Jandy Aquapure 1400
I think it’s primarily a safety and ease of installation choice. Return plumbing can get complicated with pool/spa combos, waterfalls, deck jets, etc. and you want to ensure that the acid injector will always have water flowing past it no matter what particular feature is running. You don’t want a “dead pipe” with acid being injected into it accidentally. As a manufacturer, Pentair has to “design for stupid” because you can never know just how dumb people are …
I have the acid pump relay powered by the filter pump relay - to help ensure that the acid pump can only get power if the filter pump is running. I also have the injector on the return side before it gets to the split and valves for the pump vs the pool. Just to be safe, I changed the setup so that the acid feed runs when the SWG does not.
