I will be installing new irrigation lines in my backyard, and figure it's time to add autofill to my pool. Currently I fill my in-ground gunite pool using a hose because there is no fill line going to the pool. Phoenix AZ area, so lots of evaporation.
I don't want the pool edge style autofill that connects to a hose. I'm also willing to risk a leak going undetected when using autofill.
The LevelSmart seems like the only solution to this problem. They claim that I just need to splice their valve into the return line, and add a water supply to that. The wireless transmitter then opens the valve when the water level gets too low. LevelSmart™ Wireless Autofill
Two concerns with LevelSmart:
One more thing. One side of my pool deck is 36" from a planter bed (where a new irrigation line is going), and I'm planning to put pavers over the pool deck, so I could potentially cut into that. Maybe there are other retrofit autofill options besides LevelSmart?
- It's expensive. $700 for the equipment.
- The plumbing setup seems unconventional. What happens if the autofill starts at the same time as the pump is running? This old thread is asking about this plumbing setup, and gets negative feedback from most respondents. Plumbing auto-fill at pad... where to tap in?
