This is one of many times I've checked to find this mess growing here! As it heats up, it's getting worse. I used to pour a bit of liquid chlorine, let sit, dip any residue, and bucket flush, but a simple autofill should not be the high maintenance item on a pool, it is a maintainer by its job description. I've even dropped in bits of broken tabs. The equalizer port into pool is even brown stained in the I.D. of port.
Since I don't want this to be source of contamination at some point, if it already is not, other than a small floater and tab system, any ideas? Leave it all be, not enough to worry about?
Just seems that for all the sanitation a pool requires, these things are cesspits hooked right into the system with no way to sanitize.
