New pool with auto-fill I had installed. Probably, like it's designed, it's working fine, but I just don't see the longevity of the float design working for much time. Maybe I'm wrong!
It's basically a standard, self-contained, toilet bowl float, which I understand not re-creating the wheel aspect of the float use. Probably lasts years and years in a toilet.
My observation is that the float fills the chamber, shuts off, then the reservoir gravity drains to pool till float kicks back in. Of course, this creates a constant cycling that can go on for a long, long, time till level in pool is reached. I see the pins wearing out on the float in short order. Even if I could adjust the float's range of operation, the gravity discharge would not keep up to fill rate.
When the replacement time comes, any alternative mechanism?
