I probably know the solution but thought I'd ask...or maybe see if this is a common problem.
The solar reel has plastic screws that penetrate through the top of the cover and insert into the clip that holds the strap (on the bottom side of the cover). Well, they are plastic screws and several of ours stripped at the slightest bit of pressure during installation.
So what is a good replacement?
My thought is either a plastic rivet or plastic screw with a plastic nut on the other side. I'll make a trip to the hardware store this afternoon to see what I can find. Or maybe find something on Amazon.
