- Jun 1, 2018
- 14,088
- Vinyl
- Hayward Aqua Rite (T-15)
Use a 10ml sample, a heaping scoop of dpd powder & each drop counts as .5
This will save reagents & be plenty accurate. It’s also less drops to keep track of.
Be sure to do the test the same way each time (a speed stir helps with this & lets you focus on the counting)
Hold the bottle completely vertical & let the drops come out. About a drop per second. Don’t squeeze the bottle.
Do the test, call it & move on. Doing it over & over in short succession is only using more reagents & confusing things.
No need to do an Overnight Chlorine Loss Test until you’re crystal clear with no recurring algae (dead or alive).
