Kwikee
0
If you cut flush at the join between the T and the feeder, then heat the inside of the cut off stub that is left in the T with a heat gun (or paint some pipe cement in there and light it, that's the ghetto way!), you can work some pointy nose pliers into the join and then twist, and the softened pipe will pull away from the bond and twist up onto the pliers until it pulls away.
@Danjaymor: that's a nice ideal, but reality is the cement is just that. The primer and then the solvent in the cement do start to soften the PVC at the joint, but the cement still forms the bonding layer between the two surfaces and will soften with heat.
I say this from experience as I have done it many times, both old and new joints. Your biggest trouble will be getting the heat in there evenly so you can twist it out without deforming the T.
Good luck!
Good luck!
