- May 26, 2011
- 47
- Vinyl
- Liquid Chlorine
We are getting close to closing our pool for the season and added dry stabilizer to increase our CYA from 30 to 40. We had been running CYA most of the summer at what we thought was 30 CYA per TFT pool test kit. We only use liquid chlorine and do not use pucks or other stabilizer. Gradually over the course of the summer the CYA dropped to 20 from rain and adding water due to evaporation. In mid August we added 1500 grams of dry stabilizer to raise CYA back to 30. Per Pool Math 1500 grams for our pool should raise the CYA by 11 which it did. At the end of August we added another 1500 grams of dry stabilizer to bring CYA up to 40 to 50 which I understand is the correct CYA for closing a pool with a mesh cover. When we tested the CYA today the reading was 70. According to Pool Math the CYA reading should have been 40 no more than 50. I am trying to figure out how this happened.
I have 2 questions;
1. I understand CYA levels can be tricky to interpret but I am curious to know if for some reason it is easier to interpret CYA readings at higher CYA levels than at lower CYA levels. It looked like 30 when we started adding dry stabilizer. We actually recorded 30 because the reading was between 20 and 30 and I have read that in this case you should go up to the next number.
2. Did we add too much dry stabilizer over too short a period of time?
I have 2 questions;
