Started about a month ago, when pump turns on, AquaRite shows check salt (solid) but does not generate. Moving from Auto to Off and back to Auto it will begin generating. I replaced the salt cell, same result. Then replaced the pcb, same result. The unit is set for the T-15 cell.
I searched and found there is a calibration procedure, so I had the water tested at Pinch-a-Penny. The salt is 3200. I started the pump, switched from Auto to Off, back to Auto, waited for the relay to click then hit the button 5 times. -3600 was on the display and then it went to -3500 but no lower. the display eventually switched to the default, so I hit the button 5 times again and -3500 is still there. Tried this process several times with the same result. It never drops below -3500.
