You can access the cord wires where they connect. You can measure DC amps using an inline or clamp method.
You can access the wires by clamping around the blue or red wire or using an inline test in the red or blue wire.
For an inline test, just disconnect the red or blue wire and put the meter in series so that the current goes through the meter.
You're going to be measuring current. We're assuming that the voltage is probably ok.
The voltage should be between 24 to 30 volts dc and the current should be between 5 and 8 amps dc.
Maybe show a picture of your test setup to verify before you power the cell to make sure that it's correct.
Do you want to do a clamp on test or an inline test?
What meter do you have?
Try a new cord. At least we know what the amperage is with this cord.
I don't know the exact shutdown amperage, but I suspect that it's close. Maybe 5.5 amps.
You can try a new cord and maybe a higher salinity and see if the amperage goes above 6.0
You should be about 6 to 7 amps right now.
No, that's not good.Can I disconnect the cable and put the MM between the leads while the SWG is running and outputting power through the cable?
Yes, that's the correct way.Or should I do it the way I did with - set to 0, put in the MM, then crank it back up?
If the cell is good, the amps should be about the same in forward and reverse. If the amperage is more than about 0.5 amps different, the cell is bad or going bad.Also will it show different amps depending if it is on normal or reverse cell operation?
Yes, the amperage begins to drop as the cell begins to fail. You can check the voltage going to the cell if you want, but I suspect that the voltage is probably OK or it would give an error.So is amperage a function of cell condition?
OK, the inline method should give the same information.I ordered a clamp on DC current meter so I can get real time current output when the SWG is in an alert stage.
I suspect that the polarity is not reversing because the cycle never completes. Most likely, the cell is failing. I would try a new cord and a higher salinity to see if you can get a sustained current above 6 amps.
The actual current probably goes to about 8 amps maximum. The 6 amps is probably not accurate.They show max 6 amps for output. - 22-30 VDC @ 6 AMPS maximum
The plates are coated with platinum group metal compounds that act as catalysts for the electrolysis reactions.
Over time, this coating fails and the production drops below the preset limits.
I suspect that if you removed the screws and took the cell apart, you would likely find the problem.
If the cell is less than 3 years, file a warranty claim.
