Hi Everyone,
Quick question on an aquabot classic repair. The pump motor stopped working, so I took it apart, soldered in new capacitors and got it working again, no problems. Now the confusing part for me.. The capacitors were initially in some sort of sealant/epoxy about 1". So far I've read, replace it with Duct Seal, Sik N Plus, or some sort of Marine grade epoxy resin and hardener. I personally am leaning towards the duct seal, or GE Silicone but wanted to ask 2 questions, do you know what the original material was (I attached a picture), and which of these will actually work? I'm going to bucket test it first, so if it leaks, I'll just try something else. I thought the cable might have been what is technically the waterproof seal, so I don't think this necessarily is for waterproofing, but I can be wrong on that. Any advice/suggestions would be great, thanks!
