I found several posts in TFP about trying to replace the battery in the AQL2-POD2, but no solutions. Except for one guy who wants to sell you the service.
Well, here is my solution, which is working fine. It's simply a matter of finding a battery with the third thermistor wire and swapping connectors:
- Find a battery on Amazon or eBay that meets the requirements: 3.7V and 1130mAh. The 3.7V is a must, and the mAh can be more, but not much more without making the physical size too big. Here's the one I used from Amazon, and here's a link from eBay for a variety of sizes and connectors. I never did sort out if any of those on eBay was already the right connector, but I was not optimistic.
- Get yourself a T-8 torx screwdriver to remove the back panel of the remote. This is the square POD 2 remote, and not the original handheld version. 6 screws and you're good to go.
- Remove back panel, set aside.
- Disconnect battery. And a warning: you need a soldering iron and nimble fingers to make the connections work since the wires are a bit small. But definitely doable.
- Cut the wires on the original battery close to the battery so as to give yourself some extra wire to work with. This is an act of faith - I cut half way in case I had to go back, but I would go all the way to the battery if I did so again.
- Cut the wires on the replacement battery close to the connector.
- Solder red-red, black-black, yellow-yellow. Insulate each wire with electrical tape.
- Reconnect battery, screw on cover.
- Done. Place in cradle to charge.
