Replaced the blower vacuum switch with the correct model (the other one did work for quite a while before this problem initially started.) When I turned on the power, first thing that came up was the bd code. Tried again, and every single time after that JUST received the AO error. Never saw the bd code again. So, same result, 3 or 4 clicks, then just sits for a bit, then AO. No spinning of blower, nothing else. Just the clicks. Even tried replacing the hose again.A lot of things seem to be "off" in what you are showing. The 3 pressure switches seem to have different WC setpoints ???? Which one was the correct original ?? Original Blower motor FDXLBWR1930 has 1 black wire and 1 white wire, but the one that you are showing has 1 white wire and a (blue+red) wire??? Are any of these parts OEM original ? You can't just replace parts with something that "looks" the same !
