STARLOG Dome Update: The Law of Unintended Consequences
Not being able to leave well enough alone, I fooled around last month to automate/Smarthome integrate the heretofore not-smartthings PE653 Intermatic.
Had it apparently working like a dream after using some hack code device controller and polling pistons written in webcore. I could set schedules, alerts, and thanks to the polling, switch status updated no mater where you turned anything on or off.
But for reasons we could not debug, the pump circuit would spontaneously shut down every now and then...but 3 times in the last week. The times were odd and unrelated to any scheduling. It was like there was a ghost in the system or that somehow polling commands took the circuit down.
Since the last shutdown was during freezing temps and went noticed for several hours (though my baby AI did try to tell me with an alert I'd programmed) the result was that I again froze the heat exchanger on my air warmer for the second time this season ;(
Hubby said I could not troubleshoot without tearing down my whole wobbly set of smartthings code and removing all my devices and switches. Feel like I just killed Baby Hal. So sad. Will try again in warmer temps when the stakes aren't as high.
In the course of this mess I did figure out a way to not-pay-another-$1000 for what would be a 3rd air warmer exchanger...found a new exchanger I can swap into the housing at literally a tenth of the cost. So if any future dome-owners ever freeze up their air warmer and want a cheaper, non-emergency fix, PM me for part info
Otherwise, dome life as gone swimmingly, all things considered
