Are you replacing the motor on a 3/4 hp pump or the 1 hp pump you stated in your first post?
Either of those motors should work if you're replacing a 3/4 hp motor, but if you go with the 2-speed you have listed, you'll lose some flow due to the impeller being sized for a smaller hp. depending on what the rating of the motor was you may not lose much at all or you may lose a good bit.
The 1/2 hp 1.6 sf motor will still work to replace the 3/4 hp 1.0 sf but it won't work to replace the 1 hp even if it has a 1.0 sf.
I hope this is not too confusing but it's important to match the sfhp (sf*hp) of the new and old motors. The new motor's sfhp can exceed the old sfhp but the old cannot exceed the new's sfhp.
As far as the 1.5 hp motor being too large for your pipes, don't worry about it. It'll add more restriction so the flow will be a little lower than if it was 2" plumbing but it won't hurt anything. Besides if you're sticking that motor on a 1 hp impeller the flow will be the same as before on high speed.
