The pump would never reach it's max flow rate. For AG plumbing, the typical flow rate is around 56 GPM. The max flow rate on the filter is usually 20 GPM/sq-ft or about 63 GPM so the flow rate is well below that. Ideally, you want the flow rate to be below 15 GPM/sq-ft per APSP specifications which is about 47 GPM. So the flow rate would be above the APSP recommendations but it is below the max flow rate of the filter. Not ideal, but it would work fine.
The PowerFlo would be around 49 GPM so much closer to ideal for that filter. Is there a reason you want to use the SuperFlo over the PowerFlo? The SuperFlo is really an IG pump and not required for an AG pool.
