First season managing pool which as yet is only just being used as water temperature starts at 22°C rising to 24°C by late afternoon.
Switched from previous owner using pucks to liquid chlorine and muratic acid thanks to recommendations on TFP.
Latest test results
FC 10
CC 10
pH 8.2
TA 120
CYA 80
CH 360
The pH is bouncing back up over 4-5 days. So looking to reduce TA steadily (it has already come down). Not filling that much so only a slight affect.
Read: “Aerate until pH rises to around 7.6 (the only way to raise PH without also raising TA)” and “Lowering the PH back to 7.0-7.2 more frequently will also speed up the process”
Question1: when adding muratic acid, if I don’t aerate will the TA increase with pH or stay lower?
Question2: can I reduce pH by a large value in one hit, or do I need to do it step by step?
Latest test results
FC 10
CC 10
pH 8.2
TA 120
CYA 80
CH 360
