Hello everyone. I have seen the threads from others and have been experiencing my heater turn on by itself during rain. Pentair has replaced the membrane and board twice under warranty. I'm finally out of warranty and put a board/membrane from Amazon on myself and it turned on during rain that same week. This is the 4th set of membrane/PCB since 2021, seems crazy.
Question: has anyone found something other than membrane/control board as the cause for a heater to turn on when it's raining?
Amplifying information:
-Pool finished in 2021 as a new build with all pentair equipment
-No automation, all manual control
-Located in Las Vegas (low humidity, little rain)
-When it does rain, it's windy and rainy falls sideways
-Pentair boards have conformal coating on PCB to "weatherproof"
-Amazon PCB has no weather proof coating
-I have seen some corrosion on the pins that connect membrane to PCB
-I have not used dielectric grease on the connectors yet, but plan to
I am going to try to seal the Amazon board with hot glue this week...the conformal coating doesn't seem to help
Any insight is appreciated.
Kevin
Kevin
