- Jun 27, 2018
- 14
- Plaster
- Hayward Aqua Rite (T-15)
Good Afternoon all,
I have read a couple of other threads regarding this similar issue. I believe I need to replace my T-5 cell. But, I'd like some confirmation from the guru's here before going down that financial rabbit hole
I had my SWG installed back in June 2018, so the cell is coming up on 5 years old. I have NOT had my SWG panel on a timer. It has power 24 hours a day, and with the flow switch, only "generates" when there is flow. However, since I changed my pump and filter a few months back, I have had steady Inspect Cell and Check Salt lights. I noticed that when the pump was not running, the No Flow light never came on, so I have since replaced it as well. When I do a reset with the diagnostics button, everything runs normal for the duration of the pump cycle. Here are my current readings and results as of today. Additionally,
I did not notice any scale buildup on the fins of the cell when I checked during installation of the new pump and filter.
Aquarite w/ T15
Panel S/N: 3A17306-106037
T15 Cell S/N: 3E17306-204244
Readings w/ pump not running:
Salt Reading: 1700
Temp: 62
Voltage: 32.5
Amps: 0.00
Output: 26%
Instant Salinity: 0
Program Code: AL-1
Circuit Board Version: r1.59
Readings after reset, while running:
Salt Reading: 3200
Temp: 66
Voltage: 26.8
Amps: 5.61
Output: 26%
Instant Salinity: -3100
Program Code: AL-1
Water Results
FC: 1
CC: 0
pH: 7.8
TA: 80
CH: 300
CYA: 50
Salt: 3000
Temp: 66
CSI: -.015
Any help is appreciated. Thanks!
Erik
Aquarite w/ T15
Salt Reading: 1700
Temp: 62
Voltage: 32.5
Amps: 0.00
Output: 26%
Instant Salinity: 0
Program Code: AL-1
Salt Reading: 3200
Temp: 66
Voltage: 26.8
Amps: 5.61
Output: 26%
Program Code: AL-1
Water Results
FC: 1
CC: 0
pH: 7.8
TA: 80
CH: 300
CYA: 50
Salt: 3000
Temp: 66
CSI: -.015
Erik
