Hi, I just stumbled on this forum, so this is my first post...hoping someone can give me some direction here. So, here's the situation. I have an iAqualink 2.0 system, and I've had no problems with it for the last six years. A few weeks ago we had a pretty bad thunder storm, and I'm assuming my equipment got hit by lightening, or at least a close strike, as the next morning I noticed my pump wasn't running any more, and of course my iAqualink wouldn't connect. I did replace my pump motor, but everything seemed to be in working order. My main iAqualink panel is still working, as it's still running the equipment, I can switch between modes, and run the pool from the panel, etc. The actual pump part seems to be working fine now, but my issue is I'm getting the dreaded "Connection Error, Could not connect to device." I've been through dozens of forums and videos and tried just about all the troubleshooting options I can find, but still no luck. Here's why I'm confused as to what the actual issue could be. Like I said, the panel seems fine, I've checked the wire connections, power cycled many times, done a reset. So for the Antenna, the previous owner actually ran a wire into the house, so the antenna is only a few feet from my router, but I've also tried running a network cable directly to it as well. If it's on wifi, I can connect no problem. It brings up the network login and seems to connect fine. I get all three lights. When I try switching to a hardwired connection, I flip the wifi switch a few times, and again, get all three lights. I have tried deleting the app on my phone, tried deleting the location and re-adding, tried doing it all on my computer, but again, no luck. The other weird thing is, if I go through the browser on my PC, it says it's connected, but when I open the window, it just says waiting for connection. I guess my question is, do you think it's a hardware issue? If so, any idea which part I should switch out? Or could it still be something with the software? I know you've all seen plenty of the iAqualink connection errors, but this one seems to be different. Thanks for your help.
