Hello. I have been lurking around for a few weeks reading all I can. I think I know my answer, just don't like it and would like some opinions.
My numbers tonight are:
4ppm FC
2ppm CC
8.0 PH
190 ppm TA
400 ppm CH
200+ CYA
Since reading I have stopped using the pucks (obviously)...and switched to liquid bleach (about 2 weeks ago). I have drained a bit a few times, but my well is unable to fill it back up, the CYA level has not changed.
I do have green algae showing up here and there and have to brush it every few days.
My guess is I need to drain this pool almost all the way down and have new water trucked in.
I realize I caused this myself after reading about how the CYA increases. The "pool store" tells me to just shock it and or replace the water.
Thanks in advance for your thoughts and guidance.
I can post pictures tomorrow if it helps.
4ppm FC
2ppm CC
8.0 PH
190 ppm TA
400 ppm CH
200+ CYA
