How do I know if I'm testing the CYA correctly? Does the black dot have to totally disappear? Do you kind of see it (because you know it's there)? If I hold the tester tube over something white it seems to disappear with less water/R-0013 then if non white service is below tube, etc. I use the T-100 test kit.
(We had to do a slam at the end of June. Followed TFP advice. Pool is crystal clear now.)
