With a CYA of 40 ppm, I would bring chlorine level up to around 8-10 ppm and HOLD IT THERE. Over the next 24-48 hours you will hopefully see that your pool is crystal clear and you are losing FC of about 4-5 ppm daily.
If you continue to lose more FC than that, then you probably need to SLAM again.
Are you covering the pool?
